PIX 515E 8.0(3) VPN client issue
Apr 29th, 2009
I have some problems connecting Cisco VPN client with PIX 515E 8.0(3). Here is the config below
access-list nonat extended permit ip 10.10.10.0 255.255.255.0 192.168.34.0 255.255.255.0
access-list inside_nonat_vpnclient extended permit ip 10.10.10.0 255.255.255.0 192.168.34.0 255.255.255.0
ip local pool vpn_clients 192.168.34.0-192.168.34.50
crypto ipsec transform-set REMOTE esp-des esp-md5-hmac
crypto dynamic-map DYNMAP 30 set transform-set REMOTE
crypto dynamic-map DYNMAP 30 set reverse-route
crypto map testVPN 10 ipsec-isakmp dynamic DYNMAP
crypto map testVPN interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption des
hash md5
group 2
lifetime 86400
group-policy Cisco_VPNClients internal
group-policy Cisco_VPNClients attributes
dns-server value 10.10.10.6
vpn-idle-timeout 30
split-tunnel-policy tunnelspecified
split-tunnel-network-list value inside_nonat_vpnclient
default-domain value test
nem enable
username admin password OMSYc0/RBnwbtEN3 encrypted privilege 15
tunnel-group Remote-VPN type remote-access
tunnel-group Remote-VPN general-attributes
address-pool vpn_clients
default-group-policy Cisco_VPNClients
tunnel-group Remote-VPN ipsec-attributes
pre-shared-key *
isakmp ikev1-user-authentication none
sarat1317 Wed, 05/06/2009 - 13:30
The configuration is right. I had a typo which created the problem. This is resolved
