ASA Transparent Multiple Context- Parsing syslog to Management context
Apr 29th, 2009
Is there a way of parsing syslogs from a context to the Management context ??(to avoid establishíng L3 connectivity to each context, NB! The asa is running Transparent). This because transparent mode doesn't support shared interface (as it could have been a solution - using shared interface).
smalkeric Tue, 05/05/2009 - 13:26
  • Silver, 250 points or more
Cisco ASDM Version 5.2F supports all the new configuration features of Cisco FWSM Software Version 3.2, as well as the new GUI, policy table, and syslog enhancements from Cisco ASDM Version 5.2. ASDM 5.2 has a new syslog enhancement called "New syslog viewer" which enables syslog parsing for customizing views based on time, date, syslog IDs, and IP addresses; and coloring of logs based on severity.
