Information about channel negotiation E1
Apr 29th, 2009
hi,
anyone knows if is it possible to negotiate an outbound ISDN b-channel between Cisco gateway 2851 and a PSTN switch of an Italian provider?
I have a Cisco router 2851 linked via E1 PRI (primary-net5) with PSTN and connected via MGCP with Cisco Call Manager v4.1.
From the debug message I note that the router choose the b-channel in esclusive mode and if, for any reasons, there is a problem on the line the call is busyout.
Thank for helping me
antonio
chadlincoln Wed, 04/29/2009 - 09:06
  • Bronze, 100 points or more
Can you post the configs of the router? Thanks.
cisirunite Thu, 04/30/2009 - 00:26
Below the lines more relevant. We have also an E1 link (via E1 0/2/0) between our gateway and our alcatel 4400 PBX.
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/1/0
network-clock-select 3 E1 0/1/1
network-clock-select 4 E1 0/3/0
network-clock-select 5 E1 0/3/1
isdn switch-type primary-net5
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/2/0
clock source internal
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn negotiate-bchan resend-setup
no cdp enable
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn protocol-emulate network
no cdp enable
voice-port 0/0/0:15
cptone IT
voice-port 0/2/0:15
cptone IT
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server xxx.xxx.xxx.xxx
ccm-manager config
mgcp
mgcp call-agent xxx.xxx.xxx.xxx 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 1 pots
service mgcpapp
port 0/0/0:15
Paolo Bevilacqua Thu, 04/30/2009 - 11:24
  • Hall of Fame,
    Founding Member
Hi, you asked this already.
You cannot chanhe the selection using MGCP.
With H.323, you are able to.
Nicholas Matthews Thu, 04/30/2009 - 12:34
  • Red, 2250 points or more
I'm not sure if this is what you're asking, but on the MGCP page you're able to specify whether you want to do 'top-down' or 'bottom-up' on the PRI page.
-nick
