glen.grant Wed, 04/29/2009 - 10:33
  • Purple, 4500 points or more
They are clusterable .
rock48567 Wed, 04/29/2009 - 10:46
Thanks for reply . In case in eight 3550 switch cluster, if one of them 3550 fails then we can replace with any 2960 switch.
Leo Laohoo Wed, 04/29/2009 - 16:04
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Take note that the 3550, 2950/3550 switches CAN use the GigaStacking GBIC while the 2960 can't. What do you use for your uplink? You can use either fiberoptic or copper.
rock48567 Thu, 04/30/2009 - 09:32
Yes, you are absoultely right. You got right point. I am using the 3350 and Gigastack GBIC for uplink. The 2960 has the SFP ports. I did not find any equivalent in SFP. I hope Cisco does not have any.
I guess I can use GLC-SX-MM SFP in 2960 and WS-G5484 GBIC in 3550 and use it as uplink with SC-LC fiber patch chords
MUHAMMAD SHAHEEN Thu, 04/30/2009 - 12:22
  • Silver, 250 points or more
Yes, you can use this combination. it works fine.
Shaheen
Leo Laohoo Thu, 04/30/2009 - 13:43
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the rating.
There's no replacement for the GigaStacking GBIC. But the clustering will also work with
either fiber or copper uplinks.
