CallManager and Mitel Phone Integration
Answered Question
Apr 29th, 2009
We have a new CEO at our facility. He used to have a Mitel 5340 IP Phone. Does anyone know if this phone can be used with Call Manager 4.1.3???
I'm hoping that using the SIP protocol I can make this phone work. Thanks in advance.
Correct Answer by Chris Deren about 7 years 9 months ago
I doubt it, first of all Mitel is not approved phone set, but it does not mean it will not work. Check out this website for approved third party sip phones and list of features:
http://www.tekvizionlabs.com/3rdpartyprograms/sip_verification/feature_list.php
HTH, please rate all useful posts!
Chris
Overall Rating: 5 (1 ratings)
Chris Deren Wed, 04/29/2009 - 10:40
SIP stations are not supported in CM 4, you need CM 5+ for third party SIP stations.
HTH,
Chris
zebranutz80 Wed, 04/29/2009 - 10:57
Thank you for replying Chris. Do you know if CM5+ will support all of the features that the MITEL 5340 can possibly have. We have never used SIP before so this would be a big change for us.
