6500 PFC3/QOS - Policer when doing ports are set vlan-based qos
Apr 29th, 2009
6500 - sup32- version 12.2(33)SXH
Does the policer is done over the vlan aggregated traffic or it will be compute over the traffic coming in from individual vlan member port ?
Overall Rating: 5 (2 ratings)
robetrem Wed, 04/29/2009 - 12:04
We have a 6509 aith 8x48 ports. I was thinking putting a service-policy by port to rate limit and mark the trafic.
After 112 ports where the policy are applied, I reached 1022 aggregated policy used (sh platform hardware capacity qos)!! Starting at port 3/17 I have a message saying Counter not installed ... when I do a show policy-map interface
I thought that Vlan-based QOS could help but microflow policer capacity is less so I don't know ?
Edison Ortiz Wed, 04/29/2009 - 12:22
We ran into that issue on a recent customer deployment. The problem is that each policy applied to a port will use an agg-id and the hardware limit is 1023.
I covered that scenario on this thread http://tinyurl.com/c6j73c
HTH,
__
Edison.
robetrem Wed, 04/29/2009 - 12:42
Ok that my problem, so if I do microflow Vlan-Based QOS - I should be able to simulate the port policer without that agg-id problem ??
It seem that Vlan-Based QOS does not use AGG-ID like Port-Based QOS do ?
robetrem Thu, 04/30/2009 - 08:02
I have implemented vlan-based QOS putting Microflow policer on vlan.
I am able to remark (dscp) the traffic with the policer command, but I have no statistics from the command sh policy-map interface vlan and
worst then that no packet are being drop !
Have any ideas ?
Edison Ortiz Thu, 04/30/2009 - 08:06
You are dealing with switches, so you need to use show mls qos ip command for output.
__
Edison.
robetrem Thu, 04/30/2009 - 08:36
Does this tell you microflow policing is acting ok (check the attach file)?
Note : When I was doing policer without microflow the command sh policy-map interface was giving the statistics !
robetrem Thu, 04/30/2009 - 10:14
Thanks for all the answers - it is coming good for me
I have activate Netflow to see the stats.
I am using a policer on ip-src-only. From the doc it seem that we can have 64000 flow by policer.
I suppose that the Netflow table size will limit the number total of flows. have you an idea of how the Netflow table can get ?
