Native VLAN
Answered Question
Apr 29th, 2009
When using Native vlan 99 on both switches, should I prune or allow this vlan on the do1q trunk link?
The Native vlan carried untagged traffic over the trunk link?
SW1
int G0/1
switchport
switchport mode trunk
switchport trunk native vlan 99
switchport trunk allow vlan 10,20,99
SW2
int G0/1
switchport
Correct Answer by Edison Ortiz about 8 years 2 months ago
Best Practice is NOT to use Vlan1 at all. It should be left for control packets.
All packets are untagged on the native Vlan.
Overall Rating: 5 (1 ratings)
Edison Ortiz Wed, 04/29/2009 - 12:30
  • Hall of Fame,
    Founding Member
If you manually prune this Vlan, it will stop sending traffic over it and break the native vlan connectivity.
Yes, the native vlan carries untagged traffic but it is still part of the trunk.
The command 'show int trunk' will display the Vlans that are in forwarding state and not pruned.
__
Edison.
colmgrier Wed, 04/29/2009 - 12:42
Thanks for the reply.
Is it Cisco best pratice to use any vlan rather than vlan 1 for the Native vlan?
What packets are untagged on a switch that use this native vlan?
Correct Answer
Edison Ortiz Wed, 04/29/2009 - 12:53
  • Hall of Fame,
    Founding Member
Jon Marshall Wed, 04/29/2009 - 13:37
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
"Is it Cisco best pratice to use any vlan rather than vlan 1 for the Native vlan?"
Yes and in addition it also best practice to choose a vlan for your native vlan that
1) does not have any ports allocated into it for user machines/servers etc.
2) does not have a L3 vlan interface. There is no need to route the native vlan.
Jon
