Transfer failure on CME
Apr 29th, 2009
Hi Pro,
My CME4.1 has been working for over a year. Recently, for only one of the DN's, when an external call is transfered, the caller hears a short MOH and nothing. The call still shows connected at the caller end. The transfer-to DN won't ring. Internal call transfer on this DN is fine. Other DN's do not have this issue. This DN is running on 2 ephones. I tried both full consult and blind transfer, all failed. Any troubleshooting advice is appreciated.
Thanks.
Larry
Overall Rating: 4.5 (2 ratings)
Chuan Liu Wed, 04/29/2009 - 19:05
Updates:
debug ccsip all shows the failed transfer is that when transfer button is pressed, a SIP INVITE is sent to the caller; while the successful transfer in this same router shows a SIP UPDATE message is sent. Any ideas?
debug logs are attached.
Thanks.
Nicholas Matthews Tue, 05/19/2009 - 06:48
  • Red, 2250 points or more
Hi Larry,
It looks like the possible difference between a consultative transfer and a blind transfer. Blind transfer will update the caller ID, and consultative will put the call on hold.
You can see in the SDP that a=sendonly, which refers to a hold situation.
-nick
Chuan Liu Tue, 05/19/2009 - 12:06
Hi Nick,
The problem was solved by upgrading the IOS. It was c2800nm-spservicesk9-mz.124-15.T1.bin; It is now c2800nm-spservicesk9-mz.124-15.T9.bin.
Thanks.
CiscoSeinajoki Tue, 05/19/2009 - 01:43
Hi!
Sorry, I do not have any answer, but I want to tell that I have the same problem. We have CUCM6.1 with extension mobility in use and there are two DN:s which can't get external calls. Internal calls are ok.
paolo bevilacqua Tue, 05/19/2009 - 13:26
  • Hall of Fame,
    Founding Member
The thing is that this thread is about CME, not CCM.
