Massive output queue drops 6509
Apr 29th, 2009
Dear all,
we replaced our existing 3750 stack (4 3750's with GE connections) with a 6509.
Since then I see massive output packet drops on interfaces. I checked the forum and many people are talking about line cards (WS-X6548-GE-TX), which might be the reason. But the load rarely goes over 100Mbits on those interfaces and I still see drops in the range of 10% on the overall traffic.
For testing I removed all QoS config from the interfaces, but it had no positive effect. I am really looking for help on this.
Please find below the needed information:
Mod Ports Card Type Model
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP
2 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX
3 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX
4 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
* GigabitEthernet3/24 0 0 0 277914 250000 63 81000 83 0
* GigabitEthernet3/25 0 0 0 50710155 0 0 0 0 0
* GigabitEthernet3/26 0 0 0 50710155 0 0 1000 2 0
* GigabitEthernet3/27 0 0 0 50710155 0 0 1000 2 0
* GigabitEthernet3/28 0 0 0 50710155 2000 2 3000 4 0
* GigabitEthernet3/29 0 0 0 50710155 0 0 0 0 0
* GigabitEthernet3/30 0 0 0 50710155 1000 1 2000 3 0
* GigabitEthernet3/31 0 0 0 50710155 0 0 0 0 0
* GigabitEthernet3/32 0 0 0 50710155 380000 158 535000 164 0
* GigabitEthernet3/33 0 0 0 223739947 2000 0 54000 4 0
* GigabitEthernet3/34 0 0 0 223739947 0 0 1000 2 0
* GigabitEthernet3/35 0 0 0 223739947 3976000 513 3250000 467 0
* GigabitEthernet3/36 0 0 0 223739947 15000 13 390000 31 0
* GigabitEthernet3/37 0 0 0 223739947 131000 58 82000 67 0
* GigabitEthernet3/38 0 0 0 223739947 0 0 13000 21 0
GigabitEthernet3/39 0 0 0 223739947 0 0 0 0 0
GigabitEthernet3/40 0 0 0 223739947 0 0 0 0 0
interface GigabitEthernet3/35
switchport
switchport access vlan XXX
switchport mode access
switchport voice vlan XXX
no ip address
wrr-queue bandwidth 30 70
wrr-queue queue-limit 40 30
wrr-queue random-detect min-threshold 1 40 80
wrr-queue random-detect min-threshold 2 70 80
wrr-queue random-detect max-threshold 1 80 100
wrr-queue random-detect max-threshold 2 80 100
wrr-queue cos-map 1 1 1
wrr-queue cos-map 1 2 0
wrr-queue cos-map 2 1 2 3 4
wrr-queue cos-map 2 2 6 7
mls qos trust cos
interface GigabitEthernet3/36
switchport
no ip address
mls qos trust cos
spanning-tree portfast
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 05/01/2009 - 07:03
Hello Andreas,
have you seen if these drops are real and are affecting real traffic or are simply figures in the show?
This is to understand if there is a big impact or it can be seen as cosmetic, for example I see that several ports share the exact some counter value that it is unlike.
Hope to help
Giuseppe
stephenshaw Fri, 05/01/2009 - 10:35
Hi Andreas,
this may be what you are experiencing ...
the WS-X6548-GE-TX is designed to "share" 1Gig for groups of 8 ports - this is referred as an 8:1 oversubscription.
i.e. if you load up ports 1 to 8 with heavily utilized servers, this will cause drops.
Cisco recommends using the newer WS-X6748-GE-TX modules which use a matrix to achieve far better "over-subscription" ratios depending upon specific placements within the chassis. This of, course means extra cost and requires a specific IOS code on the Sup 720.
Now, if this route is not cost effective for your company, you can try configuring traffic flow control on indivdual ports/servers and/or ensure the heavy hitting servers are not on a common ASIC (which controls each indvidual group of 8 ports).
Many companies, including mine, still use the WS-X6548-GE-TX for server connections and we found using flow control for specific servers helped prevent the drops.
HTH,
Steve
Giuseppe Larosa Fri, 05/01/2009 - 10:39
Hello Steve,
I see that drops are equal for ports 32-38 in the output this is caused by this port sharing a single ASIC chip!
We have similar behaviour in C4500 4548 linecards
Thanks for your info
Best Regards
Giuseppe
stephenshaw Fri, 05/01/2009 - 10:48
Hi Guiseppe,
the matrix design on the newer line card can give up to 40G per port (pending placement in the 6509 - E chassis). However, nothing less than 20G is provisioned which takes the 8:1 oversubscription down to around 2.1:1 oversubscription - far better but is chassis specific & IOS specific. i.e. probably worth the investment for a net new Data Centre switch but may not be worth upgrading an existing one.
I'm on the hunt for the Cisco link and will post it if I can find it.
regards,
Steve
stephenshaw Fri, 05/01/2009 - 10:54
I found the reference link:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801751d7.shtml#topic3
Details on the new line card and the use of a fabric matrix were done via a direct technical session with Cisco and I'm not aware of any links that detail how the new line card functions.
I would recommend that if anyone is considering new 6509-E switches for a Data Centre environment that you arrange a technical session with your Cisco reps. to determine the specific requirements and cost.
Steve
