04-29-2009 09:42 PM - edited 03-15-2019 05:44 PM
I have small issue with VG202 customer has CM 6.1.3. I configured this VG202 with SCCP. New fax machines in and out works fine but some old fax machine outbound works fine but not inbound it just rings and rings.
In Call Manager Fax relay is enabled and Modem passthrough is disabled.
Here is the config I have on the VG
stcapp register capability 0/0 both
stcapp register capability 0/1 both
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp feature speed-dial
stcapp call-control mode feature
voice service voip
fax protocol t38 nse ls-redundancy 0 hs-redundancy 0 fallback cisco
voice-card 0
archive
log config
hidekeys
interface FastEthernet0/0
ip address dhcp
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/0
timeouts initial 60
timeouts interdigit 60
timeouts ringing infinity
voice-port 0/1
timeouts initial 60
ccm-manager fax protocol cisco
ccm-manager config server x.x.x.x
ccm-manager sccp local FastEthernet0/0
mgcp fax t38 ecm
sccp ccm x.x.x.x identifier 1 version 6.0
sccp ccm x.x.x.x identifier 2 version 6.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
dial-peer voice 1000 pots
service stcapp
port 0/0
dial-peer voice 1001 pots
service stcapp
port 0/1
Please let me know if there is any setting I can change to fix this old fax machine inbound problem.
I tried MGCP I had the same issue.
Thanks for your help in advance.
04-30-2009 10:00 AM
When the fax machine rings, if you manually pick it up does the call work?
If you put an analog phone where the fax machine is, does it work?
If you call the fax machine from an IP phone, does it pick up at all?
This may not be related to fax at all. Some older telephony devices require a larger ring voltage associated with a higher voltage from older telephony days, and do not detect the ringing voltage of new digital devices. There are third party devices made by companies called 'ring boosters' that will increase the ring voltage.
hth,
nick
04-30-2009 10:14 AM
Nick,
Thanks for your response. I did called from an IP phone it just rings and rings and there is no option to pick up a call from fax but it work's if I connect an analog phone or to a new fax machine. Just this old fax machine to be particular OKI Data Express 5600 (I think!) is not working.
This sam efax machines work if I connect to a ATA though ..does this help if it works on ATA it should work on VG202 or do you still think it may be an voltage issue.
What is the vlotage you get from these VG202's ?
Thanks for your help again.
04-30-2009 10:28 AM
Based on the datasheet for this:
Ring Voltage
50Vrms into 5 REN at zero loop length (balanced) if no DC offset
It doesn't look like the ATA lists it's ringing voltage, but it's quite possibly just a bit higher. There is a card called the VIC3-2FXS/DID-E that was released for analog devices because it was able to offer higher voltages and currents for legacy devices.
hth,
nick
04-30-2009 10:36 AM
I don't think I can ask the customer to buy all these VIC3 cards .They need lot of ports and don't think that will work.
I tried MGCP with modem passthrough and changed even the baud rate on fax machine to 9600 still didn't work.
I'm sure lot of customers must be using this for fax hope some one had same issue and resolved it.
Thanks.
04-30-2009 10:58 AM
This is a new box, and having legacy devices with voltage problems is something that has been addressed many times with the VG224 platform which is mostly equivalent to the VG202/204.
The general policy is:
1) Use the VIC3 card
2) Buy a ring booster
3) Replace the legacy devices
You can try opening a TAC case to get more details, but you're more than likely looking at one of the above.
-nick
