Adding MIBs to HUM 1.1 Evaluation Copy
Answered Question
Apr 29th, 2009
We are testing the Evaluation Copy of HUM ( Health and Utilization Manager ). When we try to load any MIB file to it, it keeps throwing an error " Please select a File for opening and not a directory". Infact we are pointing to the few Cisco MIBs only that we are interested in loaded to HUM for monitoring AS5400XM. The MIBs files ( files with extension .my ) were downloaded only from Cisco Website. Also we have placed them in the directory mentioned in the user guide which is
%NMSROOT/hum/mibmanager/mibcompiler/mibs
Not sure what went wrong, there are no dependancy files mentioned in Cisco Website for that MIB but still we have downloaded all MIBs mentioned in that URL(http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&mibName=CISCO-POP-MGMT-MIB) for CISCO-POP-MGMT-MIB .
Please do guide me and let me know if I am missing something. We want to monitor E1 Usage and DSP for AS5400XM.
Also do let us know if HUM can do formulation of the values received on polling to plot a graph based on formula. Like adding up two E1 links usage or Active DSP used in any moment against the total available, etc..
Do let us know if we are missing something.
ramanan
Correct Answer by Martin Ermel about 7 years 12 months ago
I saw this error message before and perhaps the reason is the same in your case:
when the pop-up is shown point the path to the correct directory, then in the lower part of the window the files are listed, now _DOUBLE-CLICK_ on the file name, then click OK.
just clicking on the file will only highlight the filename but will not add it to the location path at the top of the window...
Overall Rating: 4.5 (2 ratings)
Joe Clarke Wed, 04/29/2009 - 22:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need the RFC1406-MIB, SNMPv2-SMI, SNMPv2-CONF, SNMPv2-TC, CISCO-TC, and CISCO-SMI loaded in order to load the CISCO-POP-MGMT-MIB. Are all of these loaded?
netops044 Wed, 04/29/2009 - 22:20
I have loaded SNMPv2-SMI, SNMPv2-CONF, SNMPv2-TC, CISCO-SMI loaded in the same directory, but I was not having RFC1406-MIB and CISCO-TC. But now I load them in the directory %NMSROOT/hum/mibmanager/mibcompiler/mibs but still getting the same error message.
ramanan
Joe Clarke Wed, 04/29/2009 - 23:02
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The RFC1406-MIB requires the RFC1213-MIB, RFC1155-SMI, and RFC-1212. You need to recursively go through the IMPORTS clauses in the MIBs to make sure all of them are satisfied.
netops044 Thu, 04/30/2009 - 00:12
I have copied those files as well to the same directory but still getting the same error message. The Error message we get is "Please select a File for opening and not a directory". Not sure why it should be throwing this error, when we are pointing a file only which the Server Side File Browser ( POP up that comes on clicking the option browse under Load MIBS ) lists.
Currently I have copied all the MIBs that were found under %NMSROOT/nmim/mibs as well.
Could this error message be related to wrong installation or some error in browser settings or anything else.
ramanan
Correct Answer
Martin Ermel Thu, 04/30/2009 - 02:29
  • Blue, 1500 points or more
