site to site vpn and remote access vpn
Apr 30th, 2009
hi ,
iam facing trouble in configuring remote access vpn on cisco asa 5510 on dynamic ip and site to site vpn configuration with sonicwall nsa 240 running on static ip.
following is the configuration i have made for remote access vpn
User Access Verification
Password:
Type help or '?' for a list of available commands.
ajmfw> en
Password: ********
ajmfw# show run
: Saved
ASA Version 7.0(8)
hostname ajmfw
domain-name pix.ajm.local
enable password rRiL7GeK5Rz8u8fp encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
dns-guard
interface Ethernet0/0
nameif outside
security-level 0
ip address 10.0.0.2 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.10.101 255.255.255.0
management-only
ftp mode passive
clock timezone GST 4
object-group service rdp tcp
port-object range 3389 3389
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.60.0 255.255.255.240
access-list ajmmobile_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool ajmpool 192.168.60.1-192.168.60.10 mask 255.255.255.0
no failover
asdm image disk0:/asdm-508.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 10.0.0.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
group-policy ajmmobile internal
group-policy ajmmobile attributes
wins-server value 192.168.1.100
dns-server value 192.168.1.100 213.42.20.20
split-tunnel-policy tunnelspecified
split-tunnel-network-list value ajmmobile_splitTunnelAcl
default-domain value ajmdubai.local
webvpn
username admin password f3UhLvUj1QsXsuK7 encrypted privilege 15
username youmna password aCnHruhwBOyHXsvR encrypted
username netcare password m9piWoZJb5Cm5Vy1 encrypted privilege 0
username netcare attributes
vpn-group-policy ajmmobile
webvpn
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 20 set security-association lifetime seconds 28800
crypto dynamic-map outside_dyn_map 20 set security-association lifetime kilobytes 4608000
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp nat-traversal 20
tunnel-group ajmmobile type ipsec-ra
tunnel-group ajmmobile general-attributes
address-pool ajmpool
default-group-policy ajmmobile
tunnel-group ajmmobile ipsec-attributes
pre-shared-key *
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
dhcpd dns 195.229.241.222 213.42.20.20
dhcpd lease 3600
dhcpd ping_timeout 50
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
please respond asap
mirzaakberali Sun, 05/03/2009 - 00:01
dear andrew,
right now iam have just configured remote access vpn and when i try to connect i get the following the debug messages on the cisco asa 5510 and the vpn doesnt connects.
error could not remove entry from peer table no match
please respond
asap
thotsaphon Sun, 05/03/2009 - 12:54
  • Gold, 750 points or more
Mirza,
What happens when we add this command on.
crypto isakmp enable outside
HTH,
Toshi
mirzaakberali Mon, 05/04/2009 - 00:23
yes i have configured as per the examples listed there but still it doesnt connects and shows the error on asa which i have posted below
mirzaakberali Tue, 05/05/2009 - 04:37
hi all,
one thing what i have found is that even outbound VPN connections are not passing through the asa 5510 there is something in the firewall which is blocking both inbound and outbound vpn connections.
asa ver 7.0(8)
please respond asap
as it is very urgent
mirzaakberali Tue, 05/05/2009 - 22:29
hi all,
now iam getting a new error message on the asa when i do debug crypto isakmp and ipsec and try to connect to remote access vpn from cisco vpn client
the error is
received invalid cookie message for non-existent sa
please help me
its very critical now
vpn has to be working
mirzaakberali Thu, 05/07/2009 - 06:12
hi andrew,
i have configured it as per the configuration guides from the cisco site but still my vpn is not working .
please respond to me asap
it is getting very critical. it is a crisis for me i have to solve it.
mirzaakberali Sun, 05/10/2009 - 03:53
hi andrew,
i have added this command but still no luck.i have upgraded the ios 8.0(4) and asdm to 6.21 and still i get the same error
error unable to remove peer from peer table entry group=ajmmobile no match
please respond asap
also if u can guide me how to setup ssl vpn on this which should allow full network access like mapi exchange server access will be beneficial.
eagerly waiting for ur email
regards
akber
