ACE re-direct/re-write URL to a subpage of the VIP
Apr 30th, 2009
I'd like to re-direct/re-write the URL that a user is sent to when they go to a particular http VIP.
A present the process is handled by an Apache server that we are looking to remove from the backend and utilise the available functionality of the ACE.
When a user goes to "test1.sap.brm.pri" I would actually like them to go to "test1.sap.brm.pri/irj/portal" and NOT test1.sap.brm.pri/index.html which is what is currently happening (the real backend URL wanted being http://vex1ci.sap.brm.pri:56400/irj/portal).
I created the following action list:-
action-list type modify http test1.sap.brm.pri-REDIRECT-URL
header rewrite request Host header-value "test1.sap.brm.pri" replace "test1.sap.brm.pri/irj/portal"
which at first glance I though had done the trick but unfortunately /irj/portal is being inserted into all requests to URLs that start "test1.sap.brm.pri" and not JUST "test1.sap.brm.pri", i.e.
"test1.sap.brm.pri/sap/monitoring/SystemInfo" is automatically changed into "test1.sap.brm.pri/irj/portal/sap/monitoring/SystemInfo" which doesn't exist.
Is what I'm after possible?
thanks in advance
Matthew
Gilles Dufour Wed, 05/06/2009 - 01:57
  • Cisco Employee,
Matthew,
some theory first.
A url like http://mycompany.com/path/file is composed of a hostname : mycompany.com and a uri: /path/file
When this url is sent by a computer it is clear split in those 2 parts:
GET /path/file....
Host: mycompany.com
So, when you do a header rewrite to modify the host, all you do is change the line Host: ....
Clearly this won't work.
You have to
1/ create a class-map to match the url "/" and/or "/index.html"
2/ create a redirect serverfarm/rserver to point to the new url.
3/ create a policy-map type http loadbalance to link the url class-map with the redirect and to the link the class-default to your serverfarm
Hope this helps.
Gilles.
