How to block IP communicator from registering in CME
Apr 30th, 2009
Customer wants to block some users PC(IP Communicator)not to register in CME
Overall Rating: 5 (1 ratings)
Brandon Buffin Thu, 04/30/2009 - 05:57
Disable auto registration and remove the ephone configured with their MAC address.
Brandon
Brandon Buffin Thu, 04/30/2009 - 06:07
The commands are:
router#conf t
router(config)#telephony-service
router(config-telephony)#no auto assign
Hope this helps.
Brandon
Nicholas Matthews Thu, 04/30/2009 - 10:03
Technically the phone will still register. It just won't get a DN. As well, you can specify multiple ranges so you would need to delete the specific range that has been defined.
The command you're looking for is:
telephony-service
no auto-reg-ephone
As said previously, make sure there isn't an ephone with the mac address defined. You'll need to delete that.
hth,
nick
