Controllers rebooting
Apr 30th, 2009
I have 2 controllers each are part of a different module (WiSM) and both keep rebooting (not at the same time) , both module are located within the same chassis.
When this started i had version 4.2.99 so i upgraded to 4.2.176 but it keeps doing it.
I also reseated both.
Any suggestions???
Thank you
Vic
ericgarnel Thu, 04/30/2009 - 05:49
  • Gold, 750 points or more
What is the IOS on the 6500?
Also, what power supplies are installed?
How many total blades are in the chassis?
what do the following cmds on the 6500 show?
show module
sh wism status
sh wism module controller <1 or 2> status
sh power available
sh power redundancy-mode
sh power used
sh power total
sh module power
sh module
and of course, sh logg
you may want to also debug wism events and debug wism wcp
On the wisms,
do a show running-config
under management|tech support|click on controller Crash.
and look at syslogs too
My 1st guess is that the new code draws more power from the chassis and you have exceeded the power budget of the pwr supplies installed
Victor Fabian Thu, 04/30/2009 - 06:53
I noticed you mention that it might be a power issue because of the new code , but the thing is that it was also rebooting with the old code 4.2.99 as well now we have 4.2.176 , the most interesting thing is that we had those modules running for almost a year before they started rebooting .
We haven't changed anything in terms of the software is concern.
I have attached some of the information you requested
CFayNTAdmin83 Thu, 04/30/2009 - 07:28
I ran into a very strange issue with one of my 4402 WLC's before. After a WCS server upgrade, one of the WLC's would reboot every 45 minutes. Very odd. I was able to remedy the problem by going onto the the WCS server and telling it to refresh config from controllers (delete if different). There must have been a discrepancy between the WCS server and the WLC. Haven't had any issues since... I know the 4402 is a standalone controller and not a Wism, but if you can verify that the reboots aren't power related, you may want to check into that option if you have a WCS server. This was noticed on the 4.0 and 4.1 WCS code; I tried updating the WCS version first but it didn't solve the problem...
Victor Fabian Thu, 04/30/2009 - 08:03
I actually upgraded the WCS version pretty much the same day that i upgraded the WiSM from 4.2.62.0 to 4.2.110.0 . how can i check whether WCS has a different configuration that the one that the controller has .
Thank you
CFayNTAdmin83 Thu, 04/30/2009 - 10:06
I'm using the 4.2 WCS code, but I'd imagine the steps are very similar across similar code versions.
1. Once you login, go to CONFIGURE --> CONTROLLERS
2. Highlight the check box next to the controller you want to sync.
3. Then choose the "refresh config from controller" option from the "Choose a command" drop down link.
4. Choose the delete option.
This will send the config from the WLC to the WCS database, making them the same...
Hope this helps!
Craig
kfccolonel Thu, 04/30/2009 - 17:45
With a WiSM, you should have a defined WiSM 'service' vlan in an unrouted range for WiSM to 6500 communications.
Make sure that vlan is NOT trunked anywhere. Remove that vlan from other trunks.
This solved my sporadic WiSM reboot issues.
George Stefanick Fri, 05/01/2009 - 14:43
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Have you checked the crash log on the controller? Over the last few years i have had a few controller reboot on their own. It was found later to be a bad run of controllers. Each time there was a info in the crash log.
Leo Laohoo Mon, 05/04/2009 - 16:49
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Vic,
May I suggest that you move one of the two WiSM to a different slot?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
