Remote ring and led signalization
chrisluven Thu, 04/30/2009 - 08:01
Maybe you wanna try if there is a doorbell wich is Plugable to analog telephone lines.
If it is possible just configure an ata as share line and plug the bell into the ata.
The bell now rings and you can go to the IPphone
Rob Huffman Thu, 04/30/2009 - 08:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Alexandrine,
The Strobe/Loud Ringer will need to be connected to an Analog ATA (as a shared line with IP Phone) or FXS Port. So if the DN in question is 5444 on the IP Phone you would setup an ATA, FXS or VG202 with the same DN (5444) so this analog connection can trip the cct. needed to activate the Strobe/Loud Ringer . I have had good luck with the Viking product line :)
http://www.smarthomeusa.com/Shop/Phone/Viking-Phone-Accessories/Item/BLK-3-EWP/specifications/
http://www.algosolutions.com/pdf/AN-0703.pdf
Hope this helps!
Rob
chrisluven Thu, 04/30/2009 - 08:16
Nice Description Rob, ( 5points )
I was a little bit lazy in describing the possibility of ata's.
greetings
Chris
