port-security on portchannels ?
gnijs
Level 4
Level 4
switchport port-security maximum 40
1) Does anyone know if this is supported on C3750 switches on Portchannels or will be supported in the future ?
2) Will it work if i configure it on the physical interface, instead of the Portchannel interface ?
You might think, why on earth put this on a portchannel ? The portchannel only has one vlan allowed, and it connects to a HP Blade PC chassis with 20 internal PCs. Max mac address is so 40 (dual nic PCs)
regards,
Geert
Edison Ortiz
Geert,
It's not supported at the moment and I don't think it may be supported in the future due to its complexity.
Based on the current documentation:
Port Security Configuration Guidelines
Follow these guidelines when configuring port security:
•Port security can only be configured on static access ports or trunk ports. A secure port cannot be a dynamic access port.
•A secure port cannot be a destination port for Switched Port Analyzer (SPAN).
•A secure port cannot belong to a Fast EtherChannel or a Gigabit EtherChannel port group.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_46_se/configuration/guide/swtrafc.html#wp1038501
HTH,
__
Edison.
