Delete Startup Config
Answered Question
Apr 30th, 2009
Just need help erasing the entire startup config on a switch running s72033-ipservicesk9-mz.122-18.SXF5.bin
I used write erase, it didn't work.
Please help
Correct Answer by Edison Ortiz about 7 years 9 months ago
Are you replying 'Yes', when prompted to save the configuration before rebooting - after the 'write erase' command?
If so, you are copying the running-config (which has the current configuration) back to the startup-config. In other words, you are undoing the 'write erase' process.
__
Edison.
Correct Answer by John Blakley about 7 years 9 months ago
Ah. Don't write mem after "clear start". You're rewriting the startup file when you do that.
Do clear start, reboot. No write mem. =)
HTH,
John
Correct Answer by lamav about 7 years 9 months ago
Hi:
Switch#dir all-files
Directory of flash:/
2 -rwx 365 Mar 1 1993 00:24:39 +00:00 system_env_vars
3 -rwx 7465382 Mar 1 1993 00:23:53 +00:00 c3550-ipservicesk9-mz.122-35.SE5.bin
4 -rwx 24 Mar 1 1993 08:16:38 +00:00 private-config.text
5 -rwx 0 Mar 1 1993 00:24:39 +00:00 env_vars
6 -rwx 4300443 Mar 1 1993 00:43:16 +00:00 c3550-i5q3l2-mz.121-22.EA10b.bin
9 -rwx 5 Mar 1 1993 08:16:38 +00:00 config.text
15998976 bytes total (4230144 bytes free)
Directory of zflash:/
Directory of system:/
3 dr-x 0 memory
1 -rw- 2120 running-config
2 dr-x 0 vfiles
No space information available
Directory of nvram:/
382 -rw- 5 startup-config
383 ---- 24 private-config
393216 bytes total (393135 bytes free)
Switch#
Switch#del nvram:startup-config
Delete filename [startup-config]?
Delete nvram:startup-config? [confirm]
Switch#
Victor
Overall Rating: 5 (3 ratings)
anjery1234 Thu, 04/30/2009 - 09:14
I did erase start.
The system took the command, i write mem, i reloaded; startup config still there.
Correct Answer
John Blakley Thu, 04/30/2009 - 09:16
HTH,
John
anjery1234 Thu, 04/30/2009 - 09:27
Thanks a lot John. You saved me. worked perfectly.
All config gone except vlan config.
200 RM_VIP_10.70.63.0/24 active
201 LDAP_VIP_10.66.132.0/24 active
John Blakley Thu, 04/30/2009 - 09:29
Great! If you want the vlans deleted, you'll need to delete the vlan.dat file in flash:
Switch# del flash:vlan.dat
Then reload the switch and your vlans will be gone also.
HTH,
John
John Blakley Thu, 04/30/2009 - 08:28
Write erase will clear out nvram. Since you said it's a switch, what are you trying to clear? If you do a "dir nvram:?" do you see a "nvram:startup-config" listed?
HTH,
John
Correct Answer
lamav Thu, 04/30/2009 - 08:59
Hi:
3 dr-x 0 memory
2 dr-x 0 vfiles
Switch#
Switch#
Victor
anjery1234 Thu, 04/30/2009 - 09:41
This worked fine.
My mistake was the fact that after del nvram:startup-config, i was doing wr mem again.
anjery1234 Thu, 04/30/2009 - 09:17
John,
This is what is listed
1918 -rw- 19750 startup-config
1919 ---- 24 private-config
1920 -rw- 19750 underlying-config
1 ---- 4 rf_cold_starts
2 ---- 36 persistent-data
3 -rw- 0 ifIndex-table
John Blakley Thu, 04/30/2009 - 09:19
Do this:
Switch#wr erase
Hit enter to confirm. Reboot. The switch should come up and ask if you want to enter the initial configuration mode. You're ALWAYS going to have a startup file, it's just cleared to defaults when you erase it.
HTH,
John
anjery1234 Thu, 04/30/2009 - 09:15
didn't work.
running sup720 with s72033-ipservicesk9-mz.122-18.SXF5.bin
Correct Answer
Edison Ortiz Thu, 04/30/2009 - 09:23
__
Edison.
anjery1234 Thu, 04/30/2009 - 09:30
Edison,
You saved me.
i reloaded without the wr m.
worked 100%.
All config is gone except vlan info
lamav Thu, 04/30/2009 - 09:38
Hi:
Didnt the solution I gave you work?
Im curious...
