Moving connection from ASA5520 DMZ to ASA5505 outside
Apr 30th, 2009
I am moving Vendor B connection from a DMZ port on Loc1ASA5520 to the outside interface on Loc25505. I believe I am duplicating the configuration However, it does not seem to be working properly.
I have the following global NAT configured
global (outside) 1 netmask
nat (inside) 1
nat (inside) 1
nat (inside) 1
I do not have Access-list on outside since no traffic should originate from outside
Would the outside configuration differ from a DMZ configuration?
Let me know if you need more info?
Outside is
Inside is
Overall Rating: 3 (1 ratings)
John Blakley Thu, 04/30/2009 - 08:41
Well, according to your outside and inside configuration, this won't work. The nat(inside) commands don't reference a address to go out on. I'm not sure what's not working, but if it's internet access, or any traffic originating from the inside, try adding:
nat (inside) 1
thomuff Thu, 04/30/2009 - 09:23
sorry is IP address on my inside interface. is my first inside host trying to access vendor network and it should translate to
John Blakley Thu, 04/30/2009 - 10:24
Ah, yeah, you could take that off and see if it works. (Although I'm sure you've done that already.) :)
thomuff Fri, 05/01/2009 - 13:17
Removing the netmask from the global NAT fixed the issue.
Thanks for your help.
