Meetme Conferencing: Question about number of ephone-dns....
Answered Question
Apr 30th, 2009
In the Meetme Conferencing configuration guide, the example shows maximum participants of 16 and maximum sessions of 1.   So, when setting up the ephone-dns, you would use 8 dual-line for a total of 16 participants.   However, it does not say that if you are allowing more than 1 session, do you have to create another 8 dual-line ephone-dns for each of the sessions??
For example...   If I want to allow 3 sessions with 16 participants each at one time, do I create 8 (dual-line) DNs x 3, so a total of 24 dns?
Correct Answer by Marcos Hernandez about 7 years 8 months ago
Correct Answer by Eivind Jonassen about 7 years 8 months ago
Hi Brandon,
You can´t have more than 1 session with 16 participants at a time if you use mixed mode. If you use G711 only, then you can use 4 session at a time.
Check out this guide on how to set it up:
http://uc500.com/files/CME-4-1-HW-Conf-Tech-Tip.pdf
Eivind
Overall Rating: 5 (2 ratings)
