transfer hp switch settings over to new cisco switches
Apr 30th, 2009
hp procurve 2650 and cisco 3750 switches.
can i copy over the startup-config cmds from the hp and paste them in the cisco?
Giuseppe Larosa Thu, 04/30/2009 - 10:02
Hello Jose,
I wouldn't try the two command syntaxes can be similar but not the same for clear copyright reasons.
Hope to help
sicknessjb Thu, 04/30/2009 - 11:15
then what would be the easiest way of transferring settings over.
lamav Thu, 04/30/2009 - 11:34
The best way to go about doing this is to understand that configuration of the HP switch in its entirety and configure the 3750 from scratch.
I really dont recommend just copying and pasdting commands that you dont understand.
I know this is the path of greater resistance, but it is the right way to do it, IMHO.
