Jaime Valencia Thu, 04/30/2009 - 11:25
the directories are not even pulled from SQL/informix so no.
if you use AD you can have them share the same AD containers.
if DCD/informix you can only replicate between cluster servers.
otherwise create a custom script and provide the 5 options for search or create one very customized script to search all servers
java
if this helps, please rate
