What is the SSL VPN throughput performance on ASA 5505?
Apr 30th, 2009
The Maximum 3DES/AES VPN throughput on ASA 5505 is 100Mbps, what is the SSL VPN throughput performance on ASA 5505?
Any 64 byte Packets per second(PPS) value on ASA 5505 SSL VPN?
srue Thu, 04/30/2009 - 10:18
  • Blue, 1500 points or more
good luck finding that data. i don't think it exists. ssl vpn's are more hardware intensive than ipsec vpn's, so don't expect comparable throughput.
Wintel_Cisco Thu, 04/30/2009 - 10:33
Thanks for your reply.
I know the SSL VPN is slower than the 3DES/AES IPSec VPN, so I just want to know what is the maximun throughput of SSP VPN on ASA 5505, 20Mbps? 30Mbps or...
