How to assign a bandwidth for FTP
Apr 30th, 2009
For the attached topology, I've assigned 347.76 kbps as a total bandwidth including overheads for 4 simultaneous calls, I need to assign high priority bandwidth for ftp traffic. Also I should give suitable priority to the routing protocols. How can i assign priority for it, can someone please guide me, Thanks
Jaime Valencia Thu, 04/30/2009 - 11:23
  • Cisco Employee,
  • Hall of Fame,
    2011
General: To configure a QoS for the attached topolgy
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=General&topicID=.ee6c82b&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cd2becb
ccharlebois - Logis - Apr 29, 2009, 6:15am PSTNew Message!
Considering this is your assignment, I believe it's up to you to read through the documentation that has already been linked and put together a solution for yourself. The people here will typically be happy to review whatever you put together, or help if you get stuck on a particular topic or question.
The links for how to do this have already been provided.
start reading here:
Configuring Weighted Fair Queueing
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/config_wfq_ps6441_TSD_Products_Configuration_Guide_Chapter.html
Low Latency Queueing with Priority Percentage Support
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/llq_with_pps_ps6441_TSD_Products_Configuration_Guide_Chapter.html
java
if this helps, please rate
chadlincoln Thu, 04/30/2009 - 12:51
  • Bronze, 100 points or more
I would do something like this:
class-map voice
match ip dscp ef
class-map match-any sig
match ip dscp af31
match ip dscp cs3
class-map ftp
match protocol ftp
policy-map wan-edge
class voice
priority 348
class signaling
bandwidth perecent 5
class ftp
bandwidth percent ???
class class-default
fair-queue
Put in whatever percent of bandwidth you want for FTP where the ???'s are. Then apply to the interface
interface serial 0/0/0
service-policy output wan-edge
Please rate if this helped.
