RVS4000 RIP problems?
g.stufft
I am installing a RVS4000.  I am using it in router mode with RIPenabled.  I have  two subnets behind it 192.168.1.0/24 and a VLAN with 10.0.2.0/24.  The interVLAN routing seems to be working fine and both subnets can connect to the internet.  I am concerned, however, that the RVS4000 "seems" to be advertsing 10.0.0.0/8 to its neighbor via the WAN Port (192.168.250/24 subnet).  It seems to be advertising the 192.168.1.0/24 subnet properly.  Should this be happening?  Will it cause problems?  What else do you need to know to give me good advice?
Grant
Te-Kai Liu
Level 7
Level 7
It should be fine if you do not have other 10.x.y.0/24 subnets in your network.
