Nexus 5K Module & Cable question - SFP-H10GB-CU3M Copper solution
Apr 30th, 2009
The base Nexuz 5000 comes with 40 ports that need modules installed in them. I'm looking for a copper solution from the 5K to CNA.
With pictures of the cables not very large and detailed, it looks like the copper cable solutions have a built in module on one end that slips into one of the port on the 5K, but no details on the other end.
Would it be correct to say that the SFP-H10GB-CU3M would slip into a module slot of the 5K on one end, be copper, then have a Rj45 connector on the other end to plug into a 10 Gig NIC/CNA?
If not, what would be the copper solution from the 5K to a NIC/CNA, as the only standalone modules I'm seeing in the configurator are fiber.
Thanks all!
