Tunnel not working until remote peer initiate some traffic
Apr 30th, 2009
Hi all,
I have configured a vpn that just working it, when we initiate the traffic. If remote to try initiate any connection, will be unble to make it.
Do you know why should is heppening this?
Just this peer is able to initiate the traffic
access-list outside_cryptomap_1 extended permit ip 1.2.3.0 255.255.255.0 4.5.6.0 255.255.255.0
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES esp-3des esp-none
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_cryptomap_1
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer X.X.X.X
crypto map outside_map 1 set transform-set ESP-3DES
Farrukh Haroon Sat, 05/02/2009 - 06:17
  • Red, 2250 points or more
Do you have a 'dynamic' crypto map setup at one side? In that case only the side with the static crypto map can initiate the connection.
Farrukh
Farrukh Haroon Sun, 05/03/2009 - 23:37
Please post more details about the setup.
What are the VPN terminating devices, IOS?
Are you using NAT-T?
What is the routing configuration?
Farrukh
leandro.candido Mon, 05/04/2009 - 07:06
The vpn terminating device is IOS.
I dont have the information if the vpn terminating is using nat-t, the only information about vpn terminating that I have are this:
crypto isakmp policy 4
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key
crypto ipsec transform-set ZZZZZ esp-3des
crypto map XXX 11 ipsec-isakmp
set peer Y.Y.Y.Y
set transform-set ZZZZZ
match address AAAAA
ip access-list extended AAAAA
About the routing, I have a branch office that arrives via L2L until vpn and the traffic is forward to tunnel. In concern to the routing is okay.
Thank you
Farrukh Haroon Sat, 05/09/2009 - 00:49
Sorry I was away, please let me know if this issue is still open.
Farrukh
hunnetvl01 Tue, 05/19/2009 - 02:51
do a sh crypto isakmp sa
deb isakmp 255 and post the output
