Back-up from CiscoWorks/LMS V2.6 running Solaris 2.9
Apr 30th, 2009
We have noticed that back-up script finished with error below:
ERROR(1091): Fatal error: .
Backup failed: 2009/04/12 02:01:12
Please take a look at log file.
If you need more information, please let me know by e-mail
Jose Nascimento
Joe Clarke Thu, 04/30/2009 - 11:17
First, it looks like you're using /opt/CSCOpx/backup as your backup directory. This is very bad, and could corrupt your LMS installation. Do NOT use this directory. Second, it looks like you may have a problem with your cmf database. Post the output of pdshow when LMS is running.
Joe Clarke Tue, 05/05/2009 - 12:06
Either your CMF database is corrupt, or the transaction log is. First, try the following. Shutdown Daemon Manager, then run the following commands:
rm -f /opt/CSCOpx/databses/cmf.log
env LD_LIBRARY_PATH=/opt/CSCOpx/objects/db/lib:/opt/CSCOpx/lib /opt/CSCOpx/objects/db/bin/dbsrv9 -f /opt/CSCOpx/databases/cmf/cmf.db
If those two commands don't allow the CMF database engine to start, then you must either reinitialize your cmf database, or restore LMS from a known good backup.
To reinitialize the CMF database run:
/opt/CSCOpx/bin/ dsn=cmf dmprefix=CMF
