CRYPTO-4-IKE_DEFAULT_POLICY_ACCEPTED - ?
Apr 30th, 2009
What does it mean? I saw an explanation such as:
Error Message
I have this error:
%CRYPTO-4-IKE_DEFAULT_POLICY_ACCEPTED : IKE default policy was matched and is being used.
Explanation The default policy is being used because the local configured policies did not match with the peer's policies.
Recommended Action Unavailable.
____________________________________
But what should I do?
Here is my config:
R1:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
lifetime 1800
crypto isakmp policy 2
encr aes 256
group 2
crypto isakmp key ts address xxx.175.97.74
crypto isakmp key ts-licon address xxx.234.213.46
crypto isakmp key tS-irkTS address xxx.241.208.10
crypto ipsec security-association lifetime seconds 1200
crypto ipsec transform-set km4set esp-3des esp-sha-hmac
crypto ipsec transform-set liconset ah-sha-hmac esp-aes
crypto ipsec transform-set irktsset ah-md5-hmac esp-aes
crypto ipsec profile IRKTS
set security-association lifetime seconds 3600
set transform-set irktsset
crypto ipsec profile KM4
set transform-set km4set
crypto ipsec profile LICON
set transform-set liconset
interface Tunnel26
bandwidth 2000
ip address 192.168.251.2 255.255.255.252
qos pre-classify
tunnel source XXX.XXX.133.13
tunnel destination XXX.XXX.208.10
tunnel mode ipsec ipv4
tunnel protection ipsec profile IRKTS
R2:
encr 3des
group 2
lifetime 1800
crypto isakmp key tS-irkTS address XXX.XXX.113.13
interface Tunnel26
bandwidth 2000
ip address 192.168.251.1 255.255.255.252
qos pre-classify
tunnel source XXX.XXX.208.10
tunnel destination XXX.XXX.133.13
Please help. Thank you.
yahsiel2004 Thu, 08/22/2013 - 13:15
  • Gold, 750 points or more
Did you ever figure this out?
Yosh
robert.vizitiu1 Mon, 10/12/2015 - 01:02
The message means the 2 policies for negotiating IKE Phase 1 doesn't match.
You should configure on R2 also the following policy:
encr aes 256
group 2
