LDAP Sync with multiple OU.
Answered Question
Apr 30th, 2009
Hi all,
Its possible insert multiple OU in LDAP User Search Base(LDAP Authentication)?
Or the only way is insert one root with contains OU's ??
CCM ver: System version: 5.1.3.5000-3
Administration version: 1.1.0.0-1
Thx
Correct Answer by Jaime Valencia about 7 years 8 months ago
you can configure 5 user search bases
for authentication it's only 1 ou that should be the parent of all the users that will require it
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 04/30/2009 - 11:28
java
