ADSL Router supporting Multiple Public IP addresses
Apr 30th, 2009
Does Cisco have such an device and which one would it be?
I have a range of Public IP's on my ADSL line and want to host a range of different servers
Jon Marshall Fri, 05/01/2009 - 07:43
Just to add to Collin's post. What you need is a router that supports NAT and pretty much all routers support NAT.
As an example lets say you have been allocated which means you have useable IP addresses of -> The ISP will use one of these for their upstream router so a common setup would be
LAN -> R1 (wan interface -> ( router -> Internet
So you now have ->
With these address you can host your servers. So lets say you have a server with a private address of and you want to present it to the Internet as
1) On R1 interface connecting to the subnet(s) where your servers reside
ip nat inside
2) On R1 interface connecting to ISP router -
ip nat outside
3) On R1
ip nat inside source static
4) Allow access to this server on specific ports with an access-list on the outside interface of R1 eg
access-list 101 permit tcp any host eq 80
5) Apply access-list
R1 WAN interface
ip access-group 101 in
That is a rough idea of the sort of thing you will need at a basic level.
