3rd party reporting software
Apr 30th, 2009
I would like to hear some suggestions on 3rd party reporting software for CUCM. I'm looking for something that I can create reports to give to management on a weekly basis.
I would also like to know if anyone can recommend a way to look at PRI utilization on a weekly basis. I have 20 PRI's that I would like to be able to put into a chart that maps the number of channels used for the 20 PRI's as a whole. Trying to find out if we are under or over subcribed
Thanks ahead of time for any help
Jason
brandoncheah Wed, 07/22/2009 - 12:23
You can utilitze either MARS or a company called ISI call accounting software which i used at my previous job.
