Probleme with JTAPI version just after installation
rahaman.abdoul
Do you how to solve this message?
"An error has occurred while trying to resynchronize the Cisco JTAPI Client"?
iftikharsyed_2
If you see an error window you should try doing following
1. Download JTAP Client from Call manager Plugins and install it on IPCC.
2. Create c:\winnt and copy java folder there.
Now resync Hope it will resolve your issue.
Iftikhar
If this helps kindly rate the post
dsweeny
Level 3
Level 3
Are you using CRS Administration or Unified CCX Administration?
iftikharsyed_2
Iftikhar
can you tell me how you were able to resolve that? I am facing the same issue
This is so old, this is from when UCCX was called something else, and ran on a Windows server. None of this is applicable to 12.x.
