6509 Module power issue
Answered Question
Apr 30th, 2009
Running s72033-ipservicesk9-mz.122-18.SXF5.bin
Some module are not getting power.
I used to be in combined mode because I only had one power supply.
Now that i have two ps, i configured the Redundant mode and now 4 out of 7 modules are not getting power.
2 0001.c9d9.b548 to 0001.c9d9.b557 2.0 6.1(3) 8.5(0.46)RFW Ok
3 0021.553a.4120 to 0021.553a.414f 3.0 12.2(18r)S1 12.2(18)SXF5 Ok
4 0021.d871.ac10 to 0021.d871.ac3f 3.0 Unknown Unknown PwrDeny
5 0014.a981.bb60 to 0014.a981.bb63 3.5 8.4(2) 12.2(18)SXF5 Ok
7 0021.d8e7.12d0 to 0021.d8e7.12ff 3.0 Unknown Unknown PwrDeny
8 0021.d8e7.38e0 to 0021.d8e7.390f 3.0 Unknown Unknown PwrDeny
9 0022.90b8.b8e0 to 0022.90b8.b90f 3.0 Unknown Unknown PwrDeny
Please help.
Correct Answer by Jerry Ye about 8 years 3 weeks ago
Are you using using 110Vac outlets? If you are using 110Vac, the 3000W power supply can only provide 1400W Max,, if you are using 220Vac, the 3000W power supply can provide all 3000W. Please take a look at the following link.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00800a7af7.shtml#cat6k1
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Chassis_Installation/Cat6500/0apwsply.html#wp1028905
HTH,
jerry
Correct Answer by glen.grant about 8 years 3 weeks ago
You only have 268 watts left and if you notice all individual cards are drawing more than that so the system will not power up those cards because your power supplies are too small.
Overall Rating: 5 (2 ratings)
Leo Laohoo Thu, 04/30/2009 - 17:36
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Check to see if "NO power enable module " is there or not.
anjery1234 Thu, 04/30/2009 - 18:04
no it is not there.
I used to be in combined mode because there were only one power
supply on the switch.
When I installed the second PS, I configured the Redundant mode.
Might be something there!!!
Mark Yeates Thu, 04/30/2009 - 18:17
  • Gold, 750 points or more
Jeremie,
It is likely your cards are using more power than one power supply can handle. Power supplies in redundant mode only provide enough power as one of the power supplies. You will probably have to either configure the switch for combined mode or purchase larger power supplies.
HTH,
Mark
Mark Yeates Thu, 04/30/2009 - 18:29
You caught my typo. I corrected it just a few minutes ago....
Mark
Jerry Ye Thu, 04/30/2009 - 19:11
  • Cisco Employee,
Can you post the output of show power
jerry
anjery1234 Fri, 05/01/2009 - 03:18
The sh power is below.
sp01#sh power
system power redundancy mode = combined
system power total = 1952.16 Watts (46.48 Amps @ 42V)
system power used = 1683.78 Watts (40.09 Amps @ 42V)
system power available = 268.38 Watts ( 6.39 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 WS-CAC-3000W 1171.38 27.89 OK OK on
2 WS-CAC-3000W 1171.38 27.89 OK OK on
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
2 WS-X6516-GBIC 142.80 3.40 142.80 3.40 on on
3 WS-X6748-GE-TX 325.50 7.75 325.50 7.75 on on
4 WS-X6748-GE-TX 325.50 7.75 325.50 7.75 on on
5 WS-SUP720-BASE 282.24 6.72 282.24 6.72 on on
6 (Redundant Sup) - - 282.24 6.72 - -
7 WS-X6748-GE-TX 325.50 7.75 325.50 7.75 on on
8 WS-X6748-GE-TX 325.50 7.75 - - on off (FRU-power denied)
9 WS-X6748-GE-TX 325.50 7.75 - - on off (FRU-power denied)
Correct Answer
glen.grant Fri, 05/01/2009 - 05:08
  • Purple, 4500 points or more
Correct Answer
Jerry Ye Fri, 05/01/2009 - 05:47
  • Cisco Employee,
HTH,
jerry
