AIM-CUE and CompactFlash memory
May 1st, 2009
Hi guys,
I want to buy an AIM-CUE module for a Cisco 2851 router. This module needs the 1GB compact flash card (AIM-CUE-1GBCF=) to work with version 7.X. The Cisco 1GB flash card is pretty expensive, does anyone of you have experience if other CF cards work as well?
At another forum I red that the Cisco software checks on sectors (needs to be 2001888).
I am having a 1 GB flash card (SANDISK Extreme III) on spare. This card works OK in a 3845 router and is having the correct number of sectors:
Router# show flash: all
No files on device
1024540672 bytes available (0 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
Number of Heads: 16
Number of Cylinders 1986
Sectors per Cylinder 63
Sector Size 512
Total Sectors 2001888
ATA CARD FORMAT
Number of FAT Sectors 245
Sectors Per Cluster 32
Number of Clusters 62533
Number of Data Sectors 2001714
Base Root Sector 601
Base FAT Sector 111
Base Data Sector 633
ATA MONLIB INFO
Image Monlib size = 52600
Disk monlib size = 56832
Name = piptom-atafslib-m
Monlib Start sector = 2
Monlib End sector = 104
Monlib updated by = C3845-IPVOICEK9-M12.4(6)T
Monlib version = 1
Thanks in advance,
Overall Rating: 5 (1 ratings)
Nicholas Matthews Fri, 05/01/2009 - 05:47
  • Red, 2250 points or more
I've heard you can put other flash cards in there, but I haven't tried it.
-nick
Kenneth Mohammed Fri, 05/01/2009 - 06:23
  • Silver, 250 points or more
I have used other flash cards in the past, and havent had any issues with it. This is both for the compact flash in the CUE, as well as the compact flash in the router.
Hope that helped, if so please rate.
dvdhouwen Mon, 05/04/2009 - 00:34
Hi Kenneth,
Thanks for your answer, I will try it!
dual_line Tue, 05/26/2009 - 00:31
hi, did you find a replacement CF card that worked?
I need to find a replacement card ASAP.
paolo bevilacqua Tue, 05/26/2009 - 11:08
  • Hall of Fame,
    Founding Member
As indicated above, any decent brand should work. Of course ideally you want only class 6 devices.
dual_line Thu, 05/28/2009 - 02:10
Thanks Paolo.
I've tested the SanDisk Extreme III CompactFlash 1GB.
This does not appear to be supported. I receive the following error upon bootup of the AIM-CUE after completing the boot helper software installation:
Not a cisco supported CF. Please use cisco supported CF and reinstall the softw
are.
System Halted.
Any suggestions?
davidme Mon, 09/14/2009 - 07:48
Hi All,
I'm having the same problem. I had a Cisco CF 1GB card but it's stopped working and I'm loathed to spend a couple of hundred pounds to replace it. Can anyone either recommend an actual make and model of CF card that works with an AIM module or suggest how to change the attributes so it can work.
Dave
dual_line Mon, 09/14/2009 - 07:53
It's not possible to change the attributes of a CF card, they're hard coded at the manufacturing stage.
I resorted to a cheap replacement on e-bay to resolve this issue.
paolo bevilacqua Mon, 09/14/2009 - 09:18
  • Hall of Fame,
    Founding Member
And what it was so the CUE believed it's a Cisco one ?
