Set maximum utilization of a link between servers
May 1st, 2009
Hi all
I have a network with 2 sites - with a 200Mbit link between them. At each site, I have the same kind of server, and they are replicating data, unfortunately they have to do this in the middle of our working hours, which causes a lot of package loss on the link. The servers are utilizing all the bandwith.
Can I somehow set a maximum for how much traffic the 2 servers can push through the link? Lets say I only want them to push 100Mbit through.
I know this could be achieved at the server side in most situations, but these servers does not offer that option.
And I know it maybe sounds stupid, but these servers have to replicate in the working hours.
Probably there are a lot of ways to accomplish this, so if you would be so kind to paste a link where I can obtain the propriate information.
Many many thanks in advance
/Peter
Overall Rating: 4 (1 ratings)
BlueyVIII Fri, 05/01/2009 - 04:15
Depending on the type of equipment you have on each of the link you may be best to create a QoS policy that will police the bandwidth between these two servers..
Might be more information on LAN/WAN switching forums..
Good luck
pganet123 Fri, 05/01/2009 - 04:18
Thanks for the reply, Bluey.
I will dig a bit deeper into QoS, and have a look at the forum you are referring to.
Marvin Rhoads Fri, 05/01/2009 - 04:38
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Use IP qos commands, e.g., Traffic-shape Rate. See http://www.cisco.com/en/US/docs/ios/12_1/qos/command/reference/qrdcmd5.html#wp1020005 for examples.
Depending on yor platform, you may be able to narrow your policy down to the microflow level and use user based rate limiting commands such as those listed here: http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sg/configuration/guide/qos.html#wp1327746
Hope this helps. Please rate helpful posts.
pganet123 Fri, 05/01/2009 - 04:48
Thanks mklemovitch
I think these links are of great assistance. I will try to build something from them in next week.
