Problem with Mobile Voice Access
May 1st, 2009
I'm attempting to get MVA to work and am running into an issue. I followed the instructions posted by cesar on the IPT: Mobile Voice Access hairpinning set up 3 parts:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc1d36f
I have a 2801 configured as a H.323 gw in UCM with a RP (8699X) using the RL/RG I've created that points to the 2801 device.
Here's my config on my 2801 that has a VWIC-1MFT-TI in Slot 1:
Current configuration : 4642 bytes
! No configuration change since last restart
<snip>
clock timezone CST -6
clock summer-time CDT recurring
network-clock-participate wic 1
no ip routing
no ip cef
<snip>
isdn switch-type primary-4ess
voice-card 0
dsp services dspfarm
voice service voip
voice class h323 1
h225 timeout tcp establish 3
no call preserve
application
service MVA http://[UCM IP]:8080/ccmivr/pages/IVRMainpage.vxml
controller T1 0/1/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface FastEthernet0/0
ip address 10.128.2.250 255.255.255.0
ip pim sparse-dense-mode
no ip route-cache
speed auto
full-duplex
no cdp enable
no mop enabled
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.128.2.250
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
<snip>
voice-port 0/1/0:23
sccp local FastEthernet0/0
sccp ccm [UCM IP] identifier 1 version 5.0.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register MTP_MVA
dspfarm profile 1 mtp
codec g711ulaw
codec pass-through
maximum sessions hardware 5
associate application SCCP
dial-peer voice 86996 pots
service mva
incoming called-number 86996
direct-inward-dial
dial-peer voice 869960 voip
service mva
destination-pattern 86996
session target ipv4:[UCM IP]
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 101 voip
preference 1
service mva
voice-class h323 1
codec g711ulaw
no vad
line vty 5 15
access-class 1 in
codec g711ulaw
no vad
<snip>
end
I should note that we have an Ericsson MD110 in addition to our UCM. We pass all outgoing calls from both switches through the MD. We have external destinations created on the MD for our voip DNs to route the calls to the UCM. For example, I have an external dest created for 86996 in the MD where an incoming call should come into the MD (xxx-xx8-6996), it strips off the first 5 digits and passes the remaining five onto the UCM route (Digital Access PRI) we have setup.
I've tried to make a call to MVA and it pretty much just sits there and appears connected, but if I do a "sh voice call status" - nothing is listed. Please help...I know I'm just overlooking some (critical) step...Thanks.
