05-01-2009 06:10 AM
LMS 2.6 with RME 4.0.6. I have around 10% of my devices saying partialy successful with the message:-
Could not detect protocols running on the device Command failedVLAN Config fetch is not supported using TFTP.
If I run the sync arcive it works fine on the date stamp update any ideas?
Solved! Go to Solution.
05-12-2009 09:38 AM
This is known bug CSCsq66458. It will be fixed in RME 4.3 due out early this summer with LMS 3.2.
The workarounds are to upload a bogus vlan.dat file to the device, create a bogus file using the "vlan database" command, of simply ignore the partial failure for the VLAN config.
05-01-2009 08:15 AM
Are these same two errors pertaining to the same device, or do you get the protocol error and vlan fetch error for different devices?
05-06-2009 02:21 AM
Sorry for the late response the error relates to the same device in all cases.
05-06-2009 03:07 AM
The output from failed device looks like this:-
1. Same Device name PRIMARY STARTUP May 06 2009 03:18:53 Successful
2. Same Device name PRIMARY RUNNING May 06 2009 03:19:40 Successful
3. Same Device name VLAN RUNNING May 06 2009 03:20:52 Could not detect protocols running on the device Command failedVLAN Config fetch is not supported using TFTP.
05-06-2009 09:07 AM
This points to a problem connecting to the device, and running the command:
copy flash:vlan.dat tftp:
Make sure that the username and password credentials for this device are valid in DCR, and make sure that the LMS server can establish either a telnet or SSH connection to this device. Does the vlan.dat file exist on this device?
05-12-2009 04:35 AM
vlan.dat is not found on the device? i do not know much about this file, can you suggest a "fix" for this issue?
Steve
05-12-2009 09:38 AM
