Hunt List in B-ACD
May 1st, 2009
guys,
I have configure B-ACD on CCME 7.1 the welcome file is working after dialing the AA pilot number after that if i press any key to continue the Welcome prompt my call disconnects and on desired extension (which is available in hunt list it shows " 1 call in queue "
can any help plzz
my conf is as below !!
VG-MPX#sh run
Building configuration...
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.100.1.1 172.100.1.20
ip dhcp pool voice
network 172.100.1.0 255.255.255.0
default-router 172.100.1.1
option 150 ip 172.100.1.2
voice-card 0
no dspfarm
application
service queue flash:app-b-acd-2.1.2.2.tcl
param aa-hunt3 2200
param queue-le 15
param aa-hunt2 2100
param queue-manager-debugs 1
param number-of-hunt-grps 2
service aa flash:app-b-acd-aa-2.1.2.2.tcl
paramspace english index 0
param handoff-string aa
paramspace english language en
param max-time-vm-retry 2
param aa-pilot 3500
paramspace english location flash:
param second-greeting-time 20
param call-retry-timer 20
param max-time-call-retry 60
param voice-mail 4555
param service-name queue
interface Loopback0
ip address 172.100.2.2 255.255.255.0
interface FastEthernet0/1
ip address 172.100.1.2 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.3.1
ip route 0.0.0.0 0.0.0.0 172.100.1.1
access-list 23 permit 10.10.10.0 0.0.0.7
tftp-server flash:aap-b-acd-2.1.2.2.tcl
dial-peer voice 3500 pots
service aa
incoming called-number 3500
dial-peer voice 10 pots
incoming called-number .
direct-inward-dial
dial-peer voice 100 voip
service aa
destination-pattern 3500
session target ipv4:172.100.2.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
telephony-service
load 7910 P00403020214
load 7912 CP7912080001SCCP051117A
load 7960-7940 P00307020200
load 7970 TERM70.6-0-2SR1-0-5s
max-ephones 41
max-dn 144
ip source-address 172.100.1.2 port 2000
auto assign 1 to 8
system message Your current options
time-format 24
max-conferences 12 gain -6
moh moh.wav
multicast moh 239.10.16.4 port 2000
web admin system name cisco password cisco
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Feb 05 2009 01:27:27
ephone-dn 1 dual-line
number 000 secondary 17380000
label 17380000
description Test
name Test
no huntstop
ephone-dn 2 dual-line
number 001 secondary 17380001
label 17380001
description Test
name Test
ephone-dn 3 dual-line
number 002 secondary 17380002
label 17380002
description test 2
ephone-dn 10 dual-line
ephone 1
mac-address 001F.CAE9.3C7D
type 7911
button 1:1
ephone 2
mac-address 001F.CAE9.C9E2
username "Test" password 000
type 7911
button 1:2
ephone 3
mac-address 0021.5503.6F62
type 7961
button 1:3
ephone-hunt 1 sequential
pilot 2100
list 001
timeout 10
ephone-hunt 2 sequential
pilot 2200
list 002
timeout 10
VG-MPX#
can any one help plzzz
paolo bevilacqua Sat, 05/02/2009 - 10:26
  • Hall of Fame,
    Founding Member
You may have problems qith hunt-groups made with a list of one DN only.
try configuring the extensions directly under service queue.
In any case collect "debug voice application scriot" with "term mon" to see what is happening.
markus.thelen Tue, 08/11/2009 - 00:40
I ran into the same problem. The debug said something about moh= live feed.
So I set the moh in telephony service to a file in flash ...and it worked.
Kind REgards,
Markus
