Redirect a broadcast
May 1st, 2009
I have some software which broadcasts on port 36 to find a network device. The problem is the device it needs to find is on another vlan. Is it possible to redirect this broadcast as a unicast to the correct device and if so are there any issues with this i should be aware of.
Many Thanks
I'm assuming the protocol is TCP/UDP based?
You might be able to use the ip directed-broadcast, but there are a lot of security related implications to this method.
Another option I have used in the past for non-routable protocols is to TUNNEL the traffic using GRE to the remote destination. This would be the preferred method of transport.
