Inside host to DMZ
May 1st, 2009
I am unable to allow an inside host access to the DMZ. I have ip any any access lists set up on both interfaces and the following static "static (inside,dmz) [internal_ip_subnet][internal_ip_subnet] 255.255.255.0
John Blakley Fri, 05/01/2009 - 08:27
Can you post what you have? Normally to allow inside into the dmz, what you have would work, but without seeing your config it may be difficult to tell you what's going on.
HTH,
John
zulqurnain Fri, 05/01/2009 - 08:56
It looks to be your static incorrectly configured
example static (inside,dmz)[dmz_IP_subnet][inside_IP_subnet] netmask 255.255.255.255
PRI
