Robert.N.Barrett_2 Fri, 05/01/2009 - 09:35
  • Bronze, 100 points or more
They will both work fine indoors. The "better" part could come into play if you need to use something other than omnidirectional antennas, or if you plan on using PoE.
The 1142 has fixed (non-changeable) antennas. The 1250 has RP-TNC antenna connectors that allow you to use any approved antenna.
The 1250 sucks a lot more power than the 1142. "Normal" 802.3af-compliant PoE gear will not be able to power a 1250 with both radios running at full xmit power.
Also - I remember hearing about the 1142 providing better benefits to legacy (802.11a/b/g) clients than the 1250. Something about the "M-Drive" (MIMO), but I can't find anything conclusive. Maybe someone else can jump in with more on that.
afernandez0226 Fri, 05/01/2009 - 10:13
Thanks Robert,
I will be using the power injector to power the 1250. My deployment is on a house next to the beach; so I just want to learn if the 1252 will give me more coverage since it allows me to use different antennas
Robert.N.Barrett_2 Fri, 05/01/2009 - 19:47
"More coverage" is difficult to define, especially since the radios put out the same signal strength (I'm pretty sure). But you can definitely use different antennas to provide "different" or "better suited" coverage with the 1250. For instance, let's say your house faces the street and backs up to the ocean, and that you don't want to provide wireless coverage to the street in front of your house, but you do want to provide coverage in house and in the back beach area. A patch antenna mounted on the front wall of the house aimed towards (facing) the rear/beach could accomplish that. You would not be able to do that with an 1140.
Leo Laohoo Fri, 05/01/2009 - 18:48
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Antonio,
Another thing you should consider about what models to use is that the 1140, because of it's internal built-in antennaes, has a "low" profile as compared to 1250.
The 1250, designed for industrial use, tends to be significantly heavy. Since you're going to deploy it near a beach, you need to consider RUST.
Hope this helps.
afernandez0226 Fri, 05/01/2009 - 21:53
Robert/Leo, thanks at lot for your helpful comments and feedback. So it seems that the 1250 is the way to go.
Teoh Chee Hin Thu, 09/29/2011 - 09:00
there are another type 3500 also indoor wireless AP, do it good? as it also a good technology, never experience before, anyone share?
Leo Laohoo Thu, 09/29/2011 - 16:00
  • Hall of Fame,
    2017 LAN, Wireless
Take note that if you want to use the 3500 you need to have a WLC.
The 3500 supports Cisco's proprietary CleanAir.   Now, for CleanAir to work properly and efficiently it is highly recommended that you exclusively deploy APs that support CleanAir.
