CSS11501 - Offline Diagnostic Menu
May 1st, 2009
When connecting to a 11501 via the console port, I'm being prompted with username/password prompt.
Problem is I was never given this info and this CSS is in production. Is there anyway to access the Offline Diagnostic Menu without rebooting it ?
Thank you!
Manjit
dario.didio Sun, 05/03/2009 - 23:37
  • Silver, 250 points or more
I doubt if that is possible.
You can try
usr: admin
pass: system
which is the default and hope it wasn't changed.
HTH,
Dario
mduhra Tue, 05/05/2009 - 09:18
Thanks for your feedback.
I did the following instead, which worked for me as a temporary fix:
console authentication primary local
username "username" password "pasword" superuser
-M
