DSP Requirements
Answered Question
May 1st, 2009
I have a Cisco 2811 Routers installed in 15 remote locations with (2) PVDM2-16 Chips.
Each router has (1) Four Port FXO for PSTN Calls, and (1) 4-port FXS Card for FAX and Paging Connectivity.
I calculated that (2) PVDM2-16 would be plenty. (1) PVDM2-16 can support FXO/FXS Card, and the other one I calculated to support AD-HOC/Meet Me and Meeting Place Express Calls.
On-Net Calls will be IP-IP and will not require any DSP Resources.
Just need some feedback to make sure that above configuration will work fine.
Correct Answer by Jaime Valencia about 8 years 1 month ago
that's correct 8 channels from 1 DSP for analog ports and the other whole DSP for conference
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Fri, 05/01/2009 - 12:31
  • Cisco Employee,
  • Hall of Fame,
    2011
java
abbas.ali Fri, 05/01/2009 - 12:41
Thank you so much for your quick response. I knew that DSP can not be shared between voice ports and conferencing that is why I decided to go with (2) DSP per routers. One for FXO/FXS Cards, and the other one between Adhoc/Meet Me and dedicated Meeting Place Conferencing Server.
Tommer Catlin Fri, 05/01/2009 - 15:10
  • Green, 3000 points or more
i found this in the forum to help me and keep it in my notes:
DSPs cannot be shared between voice ports and conference bridges, they can be shared between voice ports and transcoders.
Keep in mind though that 1 DSP consists of 16 PVDM channels, so 16 DSPs will theoretically provide 16x16 G711 voice calls, is that not enough for you?
Each DSP can provide 8 G711 conference bridges or 2 mixed codec conference bridges, with up to 8 participants in each session.
AFAIK 1 DSP = 4 channels
If you are using a T1 then is 24 channels hence you need 6 DSP's
8 bridges with 8 particpants x 4 = 4 DSP chip
