VPIM-CUE Broadcast
May 1st, 2009
I will appreciate if someone can guide me to correct my configuration
This is what i did to send Broadcast from Unity to CUE for VPIM
1: Locations are configured normal message are working perfectly fine
2: Under the Unity express location in CUE i configure the Broadcast VPIM-ID = 4444
3: I created a VPIM subsriber in Unity with extension = 4444 and remote mail box = 4444.
4: I created a PDL inside the unity with 5555 and sending the broadcast message on this PDL whose member is VPIM subscriber of CUE= 4444.
The problem is when the message hit to my
CUE then it bounce back and says that no mail box which is true.
Is any one can help me to correct my configuration steps
Thanks in Advance
ksng2000 Mon, 06/01/2009 - 05:47
Hi Muhammad Rehan,
Did you manage to solve your vpim broadcast from unity to CUE problem? I think I have an exact same problem as yours. Just wondering whether you manage to solve it.
