Duplicate objects
May 1st, 2009
Hi all,
I'm trying to add a device, and I got side trakced with something. Upon revisiting I had to log in again and didn't see the object I was working with in the security and devices page. so, I created another object but I get a message telling me there is already an object with this name and IP in the data base. Only, I can not find it. I'm looking though the docs but haven't found anything yet.
Thank you
This is on mars (32)
Farrukh Haroon Fri, 05/01/2009 - 22:45
Usually MARS is just giving a warning because that host was already added in MARS (not as a reporting device but as a host).
Go to Management >> IP Address Management >> Change 'View' to 'Host'
Then delete that device/IP if you wish.
eegilbert Mon, 05/04/2009 - 09:18
Actually what I was able to do was to add a service to an existing device. Then I was able to choose the duplicate object, change it's IP address and give it a phony service and save/active.
After this I was able to delete the object. Not the most intuitive ;-)
Thank you for the responce.
