device not getting deleted
May 1st, 2009
device not getting deleted in Common services . the device is unknown state in DCR
Joe Clarke Fri, 05/01/2009 - 17:16
What version of LMS do you have? What exactly are you doing to delete the device? What error do you get?
gvk_kuttan Sun, 05/03/2009 - 09:02
we are using LM S3.0 ; i am deleting the device from DCR adn i dont get any error message when i check once again i am able to see the device details in DCR
Sorry for the late reply thanks
Joe Clarke Sun, 05/03/2009 - 09:46
It sounds to me like you have a pop-up blocker enabled. When you click the Delete button under Common Services > Device and Credentials > Device Management, you should get a pop-up asking if you really want to delete this device, or if you only want to delete devices that are not being managed bu any application.
gvk_kuttan Fri, 05/08/2009 - 14:01
i am getting the POP UP too ; it asks whether to continue then i click to continue \ but i dont get success message like "device has been deleted"
Joe Clarke Fri, 05/08/2009 - 17:50
Can you post screenshots showing exactly the process you're using, and exactly what you see?
gvk_kuttan Wed, 05/13/2009 - 16:31
I am deleting the Device and i have attached the screen shot after deleting ; when i search again the device is still in DCR database and not setting deleted
Joe Clarke Wed, 05/13/2009 - 16:43
Are you saying that the pop-up in screenshot 3 never goes away? Or does it just disappear on its own without a final message that the device was deleted?
gvk_kuttan Thu, 05/14/2009 - 07:46
Yes ; it just disappear on its own without a final message that the device was deleted sucesfully
Joe Clarke Thu, 05/14/2009 - 09:38
I recommend you open a TAC service request so real-time analysis can be done.
