aaa authentication
May 1st, 2009
Why authenticatiion Default and NO_AUTH. I am totally confused, please help
aaa new-model
aaa authentication login default line
aaa authentication login NO_AUTH none
line console 0
login authentication NO_AUTH
Rupesh Kashyap Fri, 05/01/2009 - 19:37
sir, for duble redundancy, we have to write the command in Single line. But here, you can see Two seperate line. And one thing more, in Console, only Auth with None is used? What does it mean ?
johnlloyd_13 Fri, 05/01/2009 - 20:45
your aaa authentication is set in a hierarchical method:
it will first try method 1:
> this means that a user authenticates using the password set on your line (console, aux or vty)
if method 1 is not met, it checks method 2:
> 'none' means no authentication is required or you automatically login into the device. the NO_AUTH is then applied to your console line
you can write an alternative single command using:
aaa authentication login {default | list-name} method1 [method2...]
aaa authentication login default NO_AUTH line none
