seek help:I meet a question about 6509
May 1st, 2009
After the 6509 Switch starts,enters directly rommon.Below is the detailed information
Router>en
Router#show ip inter b
Vlan1 unassigned YES unset administratively down down
GigabitEthernet1/1 unassigned YES unset administratively down down
GigabitEthernet1/2 unassigned YES unset administratively down down
GigabitEthernet4/1 unassigned YES unset administratively down down
GigabitEthernet4/2 unassigned YES unset administratively down down
GigabitEthernet4/3 unassigned YES unset administratively down down
GigabitEthernet4/4 unassigned YES unset administratively down down
GigabitEthernet4/5 unassigned YES unset administratively down down
GigabitEthernet4/6 unassigned YES unset administratively down down
GigabitEthernet4/7 unassigned YES unset administratively down down
GigabitEthernet4/8 unassigned YES unset administratively down down
Router#
00:01:28: %ONLINE-SP-6-INITFAIL: Module 1: Failed to synchronize Port asic
Router#
Router#host 6509A
00:02:13: %ONLINE-SP-6-TIMER: Module 4, Proc. 0. Failed to bring online because of timer event
00:02:13: %C6KPWR-SP-4-DISABLED: power to module in slot 4 set off (Reset)
Router#confi t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#host cisco6509A
Config mode locked out until standby initializes
Router(config)#
%Software-forced reload
sunxia.vip Fri, 05/01/2009 - 20:21
Breakpoint exception, CPU signal 23, PC = 0x40299B44
-Traceback= 40299B44 40297C98 4036B8B4 4036B8E4 40401740 4035BA24 4035BA80 4032DFC0 4032EE60 402E1FC4 402DF758 402DF9CC 4029DD1C
$0 : 00000000, AT : 418E0000, v0 : 41D00000, v1 : 00000010
a0 : 41CF3FB0, a1 : FFFFFFFC, a2 : 00000010, a3 : 00000315
t0 : 00000001, t1 : 0000003B, t2 : 50006CA0, t3 : 00000001
t4 : 00000352, t5 : 00000000, t6 : 50006C98, t7 : 003BAF63
s0 : 00000000, s1 : 00000000, s2 : 50329290, s3 : 50329290
s4 : 085ACBFA, s5 : 00000040, s6 : 00009000, s7 : 0000005A
t8 : 0000838A, t9 : 00000000, k0 : 00000000, k1 : 00000000
gp : 418ED8A0, sp : 50006CF0, s8 : 00000000, ra : 40297C98
EPC : 40299B44, ErrorEPC : 0D4CF57B, SREG : 3401F103
MDLO : 99999A5F, MDHI : 00000315, BadVaddr : C1A2A916
CacheErr : E4800000, DErrAddr0 : 1E02000C, DErrAddr1 : 80006B88
Cause 00000024 (Code 0x9): Breakpoint exception
Writing crashinfo to bootflash:crashinfo_20090429-162634
=== Flushing messages (16:26:34 UTC Wed Apr 29 2009) ===
Buffered messages:
00:00:42: RP: Currently running ROMMON from S (Gold) region
00:00:49: %SYS-5-RESTART: System restarted --
IOS (tm) c6sup2_rp Software (c6sup2_rp-PS-M), Version 12.1(27b)E1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 12-Oct-06 21:49 by hqluong
00:00:49: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
00:00:49: %SYS-6-BOOTTIME: Time taken to reboot after reload = 14886108 seconds
00:00:48: %SYS-SP-5-RESTART: System restarted --
IOS (tm) c6sup1_sp Software (c6sup1_sp-SP-M), Version 12.1(27b)E1, RELEASE SOFTWARE (fc2)
Compiled Thu 12-Oct-06 22:26 by hqluong
00:00:50: %C6KENV-SP-4-FANVERCHK: Power-supply 1 inserted is only compatible with Version 1 fan-tray. Please make sure fan is low-output fan-tray
00:00:50: %OIR-SP-6-INSPS: Power supply inserted in slot 1
00:00:50: %C6KPWR-SP-4-PSOK: power supply 1 turned on.
00:00:50: %C6KENV-SP-4-FANVERCHK: Power-supply 2 inserted is only compatible with Version 1 fan-tray. Please make sure fan is low-output fan-tray
00:00:50: %OIR-SP-6-INSPS: Power supply inserted in slot 2
Queued messages:
00:02:31: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debuggin
00:02:30: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:02:31: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
sunxia.vip Fri, 05/01/2009 - 20:23
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x618fc684
PC = 0x6012fe38, Cause = 0x1820, Status Reg = 0x34018002
System Bootstrap, Version 5.3(1)
Copyright (c) 1994-1999 by cisco Systems, Inc.
c6k_sup1 processor with 65536 Kbytes of main memory
rommon 1 >
rommon 1 >
rommon 1 > exit
monitor: command "exit" not found
rommon 2 >
00:00:09: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
00:00:10: %OIR-6-CONSOLE: Changing console ownership to route processor
System Bootstrap, Version 12.1(3r)E2, RELEASE SOFTWARE (fc1)
Copyright (c) 2000 by cisco Systems, Inc.
Cat6k-MSFC2 platform with 262144 Kbytes of main memory
rommon 2 >
rommon 2 >
rommon 2 >
rommon 1 >
rommon 1 >
rommon 2 > boot
Self decompressing the image : ############################################################################################################################################################### [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Leo Laohoo Fri, 05/01/2009 - 20:36
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
You need raise a TAC RMA request. Here's the reason why:
It's due to the "timer event".
Hope this helps.
