How ACS SE integrate with Oracle?
May 1st, 2009
My customer has bought ACS solution engine and would like to implement IEEE 802.1x for its wireless users for control access
a) Current user database is Oracle. I understand to integrate with Oracle, one needs to use ODBC-complaint RADIUS server but ACS SE does not support ODBC. What are the options I can have and type of EAP proposed? Should I propose EAP-PEAP MS-CHAPv2 or EAP-TLS?
b) Customer is looking into implementing Single Sign On(SSO) for wireless access. I believe only EAP-PEAP with MS-Chap v2 support SSO using windows default supplicant. Customer is not willing
c) Is there any free supplicant which can support SSO?
-Delon
Robert.N.Barrett_2 Sun, 05/03/2009 - 15:20
  • Bronze, 100 points or more
Looks like a lot of head scratching going on. I'm guessing that you need the Oracle user database to use LDAP, which should work with ACS SE 4.2.
I'm afraid I can't offer any advice on free SSO clients...
George Stefanick Sun, 05/03/2009 - 19:57
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
EAP-Peap is the most widely adopted EAP protocol. It is also pretty secure with server side auth.
Trending Topics - Security & Network
